Configures the other stateful configuration flag value sent in router discovery advertisements on the VLAN.
| vlan_name | Specifies an IPv6 configured VLAN. |
| on_off | Specifies setting the flag to on or off. |
Off.
This command configures the contents of the other stateful configuration flag in the router advertisement messages.
When set to on, hosts use the administered (stateful) protocol (DHCP) for autoconfiguration of other (non-address) information. If this command is not entered, the default value is off.
The following example configures the other stateful configuration flag to be on for the VLAN "top_floor":
configure vlan top_floor router-discovery other-config-flag on
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
